rapid mart job stop running further
Hi friends and gurus
As we are monitoring the data services jobs, we found one of the rapid mart jobs starts yesterday as per schedule timings and the end time shows 0(even after a day)
The status of the job still shows in green color
But when I turned investigating by reaching the errors tab, in the job trace log I found the log has written partially. And it never moved further and I even also tried to see in
Job monitor log I can see half of the rapid mart data flow has been loaded I.e.
DF_PM_STAGE/AFVC READY 0 0.000 5.648
-DF_PM_STAGE/AFVC_STG_AFVC READY 0 0.000 5.649
+DF_PM_STAGE/IFLOT READY 0 0.000 5.650
-DF_PM_STAGE/IFLOT_STG_IFLOT READY 0 0.000 5.651
+DF_PM_STAGE/IFLOTX READY 0 0.000 5.652
-DF_PM_STAGE/IFLOTX_STG_IFLOTX READY 0 0.000 5.653
+DF_PM_STAGE/JCDS READY 0 0.000 5.654
-DF_PM_STAGE/JCDS_STG_JCDS READY 0 0.000 5.655
+DF_PM_STAGE/JEST READY 0 0.000 5.656
-DF_PM_STAGE/JEST_STG_JEST READY 0 0.000 5.657
+DF_PM_STAGE/KAKO READY 0 0.000 5.658
-DF_PM_STAGE/KAKO_STG_KAKO READY 0 0.000 5.659
+DF_PM_STAGE/T001W READY 0 0.000 5.660
-DF_PM_STAGE/T001W_STG_T001W READY 0 0.000 5.661
+DF_PM_STAGE/T353I_T READY 0 0.000 5.662
-DF_PM_STAGE/T353I_T_STG_T35I_T READY 0 0.000 5.663
+DF_PM_STAGE/TJ02T READY 0 0.000 5.664
-DF_PM_STAGE/TJ02T_STG_TJ02T READY 0 0.000 5.665
+DF_PM_STAGE/TJ30T READY 0 0.000 5.666
-DF_PM_STAGE/TJ30T_STG_TJ30T READY 0 0.000 5.667
Job error logs: shows empty file receive
By comparing the job(which are started) with the rapid mart w/f,dataflow present in the documentation guide in Data services Management console we came to conclusion that not all data flow has started only few dataflow worked properly (others not yet started)
This was happen earlier also I thought in the next scheduling time this will be rectified but it doesn’t have any impact
Could you please help me or suggest me, what the necessary actions I have to take to ensure all the respective workflow/data flow in the rapid mart run successfully (as there is no errors stated in error logs)
Or also share your experience what might be reason of incomplete running. (As I don’t find any errors in error log)
Please help
Thanks a lot
Thanks in advance
Fasi
Md_Fasi (BOB member since 2011-11-19)
All threads READY means no a single row has been received yet. As it seems you are reading from a stage table, I would think about database locks and the such.
Thanks Werner Daehn
Let me check, and I will get back to you.
And another thing I have seen there are several other rapid mart which actually takes 5- 6 hours (avg) for data loading.But now a days it seems it is taking more than 1o hours .
Could you please suggest me the best way to increase performance and the reason of these cause
Thanks & Regards
Fasi
