Hi Gurus/Masters…
Need your urgent attention on the below issue.
while creating RM4.0 target schema I find few DDL files under datamodel folder in the setup.
I am not sure how to run that in sqlserver 2008 as that is my target database.
can somebody guide me on how to create the target schema in RM 4.0
request you to please reply ASAP.
thanks in advance
pap
sharpan (BOB member since 2010-04-29)
Hi Sharpan
Bob is not the BO tech support and all people here are volunters to help each other freely on their own time
Then avoid using such words which are in addition obvious and be patient
bernard timbal (BOB member since 2003-05-26)
Please accept my Apologies… will keep in mind next time
no problem. Sure I did it myself one time
is it not just a case of running those DDL scripts in SQL Server Management Studio ?
agulland (BOB member since 2004-03-17)
Hi Much appreciate you reply… what ami looking here at http://www.gulland.com …
can you please be more specific…
pap
system
November 11, 2012, 2:32pm
7
To buil IDM (integrated data model) on RM4.0 you need to Run the init Job
called “Load data Model” or similar.
This Job included in the Atl deployment of RM is the 1st Job you need to RUN
for building the star schema table objetcs.
zeus3000 (BOB member since 2009-04-16)
