Ranking with NULL or 0 values
Hi all,
I’m trying to rank a column, Advisor Name, by YTD Production. However, there are null and 0 values in the YTD Production column. When I do a rank, it ranks the advisor names with null values first and then ranks the rest of the names. So then I tried this formula :
=If (Not(IsNull()) Then Rank(,) —> But this does not start with ranking number 1. So then I tried this formula :
=If (IsNull()) Then 0 Else Rank(,) —> But this gives error message “Incorrect Data Type”.
Can any one suggest alternatives?
Thanks in advance.
Cindy.
NOTICE
If you are not an authorised recipient of this e-mail, please contact Mercantile Mutual immediately by return e-mail or by telephone on +61-2-9234 8111. In this case, you should not read, print, re-transmit, store or act on this e-mail or any attachments. Please destroy the message and attachments. This e-mail and any attachments are confidential and may contain legally privileged information and/or copyright material of Mercantile Mutual or third parties. You should only re-transmit, distribute or commercialise the material if you are authorised to do so.
This notice should not be removed.
Cindy,
It’s been my experience, that this is a version 4.1 restriction. Your first formula is correct, however v4.1 doesn’t deal with it correctly.
The only good news I have is that I have tested this in version 5.0, and the very same formula works as expected … ignores the dimension value if it is a NULL, and commences ranking “real” values as of number 1.
Ang.
Angela E. Bishop
Senior Consultant
BanDIT Consulting Pty Ltd
