Rank Function
Can you help me out how to use the dense rank function in DESKI report level, though i know that there is no function in DESKI report level, But my objective to get the rank.
eg xyx 2000 1
tty 2000 1
avd 1234 3
tyr 1234 3
dfr 600 5
I want the output as
  xyx    2000    1
 tty      2000    1
 avd     1234    2
tyr       1234    2
 dfr      600      3
how do i implement this in report level, i dont have access to universe only have a connection level access.
akhil (BOB member since 2008-07-19)
Deski doesn’t have a “dense rank” function, but it does have a Rank() function, which outputs the rank value for a dimension, based on a measure. The syntax is as follows:
Rank(dimension,Measure)
Can you tell me your second column is dimension or measure field ???
If it is dimension use formula as :
=RunningCount() In()
You get result as per your requirement, only you need to apply desc sorting on that dimension column.
I know this is not permanent solution … If it serve your purpose then try …
pravin_gaikwad :india: (BOB member since 2010-03-27)
