Random Sampling Using a String Field
Hello,
I have a report that simply pulls a list of IDs. The ID’s are strings however only numbers are used as the IDs. For example:
0013131342420
0012340240242
The report pulls back all ID’s. I would like to modify the report to bring back 20 randomly selected ID’s.
This sounds so simple to do but I am out of ideas and banging my head against the wall :hb: . Please Help!!
Thanks!
pete
pete171 (BOB member since 2008-09-22)
Hmmm
You could only do this in Crystal with suppression, if you wanted it pushed to the database you`d have to do it in a stored proc or a view.
In Crystal create 2 formulae (rnd1 and rnd2) that say Ceiling(Rnd()*10).
Then create a record selection that is
@rnd1 = @rnd2
This will pick off a random set of details every time the report is run.
If you only want 20 or less, just suppress the details section where recordnumber <= 20.
If I wanted 5% randomly selected, would I need to use 5 instead of 10 in the formula?
Why do you have @rnd1=@rnd2?
michcl (BOB member since 2019-09-24)
When you say create record selection @rnd1=@rnd2, do you mean to put that in section formula (filter), or select expert somewhere?
