BusinessObjects Board
Radio Button with Dynamic Visibility disappears when selectd
I believe I’ve set the dynamic visibility on the radio button correctly, however, when i make a selection in preview, the chart appears but the radio button disappears.
So, I’m not able to make another selection.
Is there something I missed that’s doing this? or is this some sort of bug?
cabosako (BOB member since 2013-04-03)
Most likely you have set dynamic visibility on the Radio button component itself, which you probably do not want. Remove it and see if it behaves the way you want.
~Roxanne P
Sr BI Consultant
InfoSol
RoxanneP :us: (BOB member since 2006-08-07)
