R3.1 Deski - tool for FHSQL connection query/change
Hi folks,
we have a situation that for several hundreds of FHSQL reports there was used a wrong connection (username/pass@db)
do you know any tool for a bulk reports change of the specific connection to another? or just to list them…?
(not a manual import, change and export)
THIA, Tomas
tom_kar :czech_republic: (BOB member since 2015-06-30)
Hi Tomas,
This can be a real challenge. DeskI in XI 3.1 has only VBA SDK and as far as I remember, changing connections in DeskI reports was not exposed in VBA. I may be wrong so you’d better check that.
maybe it could be the occasion to convert these reports in webi and the HF SQL to univers using the conversion wizard
