Question on Hyperlink
According to my requirements when the user looks at the report and clicks on the hyrelink it should give a new report, I have done this but i want to know is there a way to pass one prompt through the hyperlink and display the other prompt while opening the report. I mean can we do both passing one prompt and displaying the other prompt before the new report gets retrived.
Thank You
Follower (BOB member since 2004-06-24)
I have tried many ways to make the above thing work. But i didnot suceed. Can anyone give me an idea or suggest me a way to accomplish the above task
Thank You
This question has been discussed before…please try a search on BOB. See if this link is helpful Hyperlink
Bharat :india: (BOB member since 2004-05-03)
