Question on BOE XI 3.1 FP 2.7
Our BOE environment is currently configured with BOE XI 3.1 SP2 + FP 2.1. We are currently planning to update it with the latest Fix Pack 2.7 to fix one of the issue which is taken care of in this fix pack. Have anyone experienced any side effects with this fix pack.
Also want to know what if we opt only to replace the dll which is modified for this ADAPT, instead of having the entier fix pack. Have anyone tried it before, does changing the dll with a newer version work atall?
Please let me know.
piyushpansare (BOB member since 2010-05-04)
Same question - Any issues with 2.7?
We would be going from 2.3, following whatever SAP’s recommendation is for a successful install
  • uninstall/install
  • install over the top
  • start install, hop on one foot 22 times while wearing your socks inside out and listening to a group of penguins play rap music on accordions :mrgreen:
KevinI :us: (BOB member since 2003-03-04)
have installed the latest 2.7Fp on 4 environments (3 wind + Solaris) and no technical error occurred during the installation process. Both errors that occurred on our systems and were described as ADAPT’s are solved and do not trouble us anymore
Antremons (BOB member since 2006-03-21)
