question about Infoview installation
i am haveing a problem:
i installed BO server component , then when i run InfoView i don’t have the login phase i login automatically to a slim version of InfoView with no ability to publish report.
i need to know how to fix this problem ASAP
thx
RobeirSamir (BOB member since 2005-06-21)
It will be helpful if you can provide more information:
  1. Which version of Business Objects are you installing?
  2. What are the steps you took to install the server components?
  3. Is it a brand new install?
  4. Is the installation and configuration of the repository successful?
If you have installed 6.5 I would check what Security Configuration settings you have made. Also check that the BOMain key is in the loc data directory on your node and is called BOMain
irish_stan :ireland: (BOB member since 2003-05-13)
1- i installed BO 6.5.1 server component
2-installed server compnent with IIS and ASP , and added snap in with Win2003 server
3-the installation and configuration of the repository are successful
about Security Configuration i made it BusnissObject authintication and the BOMAIN.Key is located on loc data directory
i need a specified steps to configure security as i feel it’s the reason
thx all for ur replies and give up on me:)
It looks like authentication mode is setto “Basic” or Windows Authentication. In that scenerio, Infoview wont ask for a password.
Check if you have privilages for creating reports.
shamit (BOB member since 2004-07-01)
the authintication is made busniss objects
Hi robeir,
So is your problem solved now?
the probelm is solved now, donno how yet:)
but i have another question:
i deployed reports on InfoView but when i click on one of them error “The page cannot be found” appears
u know what’s wrong?
Hi Robeir,
You will be glad to know it is a common error but can have a number of causes. Please see that attached post If you still have any problems then just post back and we will see what we can do. Yiou have the same configuration as one of my deployments so we should be OK.
thx irish_stan for ur support:)
i tried to follow the topic u sent me but it didn’t work out so i need to know the configuration of IIS exactly to run those reports
thx
Robeir,
Do you have access to the BO Tech Support site? if so you may want to have a look at this resolution 17405:
http://www.techsupport.businessobjects.com/search/Beta/Viewtechresdb.asp?Cmd=View&Level=0&Item=3&ID=17405.
If you haven’t got access to tech support just let me know I will post it here for you
[Moderator Edit – no, this is not allowed due to Copyright Infringement.]
i don’t have acess:(
[Moderator Edit – KnowledgeBase Resolution removed - per our rules against Copyright Infringement – AMC.
And - irish_stan – URLs to a resolution do not work – they are session dependent. The best that you can do is to post the resolution number. One has to log into tech support and do an advanced search on ID.]
well i did that b4 but i did it again now and same result
http error 404 page cannot be found:S
PS: what do u mean by press the “Return” key for me return Key is Enter Key
Hi Robeir,
Do you have the “All Unknown ISAPI Extensions” allowed is IIS?. Have you rebooted the server- Stopped and Started Webi?
it’s allowed now and it worked
thx alot man:)
You are more than welcome
