Query to find out usage of reports and users accessing them
All,
I need to find out the reports getting run the most. Is there an efficient query by which i can find out which are the documents being run from the BCA and the corporate docs and who are accessing them/ scheduling them the most.
A quick response will be greatly appreciated,
M
marym (BOB member since 2006-09-21)
These informations aren’t stored in the security domain (i mean documents usage). You can partially have informations using auditor. Have a look to BOB dowload’s you can find a useful universe to run queries on BCA activity.
Thanks a ton Goiffon and Smith,
That did help a lot.
Also i also find universes called BCA and Audit which is are the security universes. Do you know of any query by which i can find out which of the reports used in corporate docs are used in the schedular. These are like 2000+ reports. I would love an easy way to get to the right answer.
Thanks again,
M
For BCA i was talking about this one.
Thanks Goiffon and Smith,
The link that you sent last was the one that i was looking for.
Thanks a ton,
Sorry for the delay in reply,
M
