Hi i have a issue regarding combination of ranking and break.
If we apply ranking for a particular column then if i apply break then i am loosing ranking.
what is the solution for this issue?
arif8700 (BOB member since 2010-06-24)
Tamman
You can develop your own custom Ranks using the Rank function
with your own custom breaks
Mick
mikca (BOB member since 2005-12-16)
thanks.i will try the way u told me.
