So the Query Prompt Selector is not supported for HTML 5, so I thought I would use a combo box to update the query results. Unfortunately when I try to select the prompt from the query in the Destination of the Combo Box, the prompt for that query is greyed out. I do not understand why.
Is there another way to filter a universe (dynamically), but not using the Query Prompt Selector? I have tried a local prompt and a universe prompt.
Also under Prompts for the Query in question, The Selected Values is greyed out, Insert List of Values is not.
SAP Dashboards 4.1 SP 7.
Solution: I used the Filtered Rows for the combo box to achieve the results I wanted. Not the best solution (prefer to filter the query).
kevlray (BOB member since 2010-06-23)
