Query Prompt is not showing LoV Values.
I am Creation Webi Report based on Bex Querys.
Firstly i created BICS Connection in IDT and Publish. After i creating WEBI Reports based on Bex Query(BICS Connection).
When i am adding Query Promt an object, the Object LOVs is not displaying. Please look at the attched Screenshot.
In LoVs Box it’s showing below Message.
Use search criteria to retrieve values.
The search is case sensitive. Here are examples of search criteria.
Search = a* -> Retrieve all values starting with “a”.
Search = a -> Retrieve all values ending with “a”.
Search = a
a -> Retrieve all values starting and ending with “a”.
Search = aa -> Retrieve all values starting and containing one more “a”.
Please help me how to resolve the issuse. Is there any steps to taken in IDT or BEx Side.
Best Rgds,
Ramesh
venkatarameshc (BOB member since 2011-06-09)
This post may help:-
https://bobj-board.org/t/185639/9
Please need helpful on this. :hb:
We are using BO 4.0 SP5.
Ram
Did you read the document linked to in the other post? Did you try the solution discussed?
