In Designer I have created a GENERAL class which contains objects such as SYSDATE, NULL etc that I can use in conjunction with other objects.
Within my universe I have contexts. I have one class that is based on an isolated table (i.e. no joins) that does not form part of these contexts.
When I try to use an object from this isolated table in conjunction with one of my general objects, I get the QP0007 error.
I’m guessing that it is trying to generate 2 SQL statements and when it hits the general object (e.g. SYSDATE), it tries to generate a SQL statement which does not have a FROM TABLE clause in it.
Does anyone have a solution to my problem. :?
[moved to Designer forum - Andreas]
Grantie
(BOB member since 2004-07-01)
(BOB member since 2002-08-08)
