Query Builder - favourite reports for a group
Hi all,
I am using query builder (BI 4.2) to export data from one BI 4.2 platform to another.
I am struggling to build the query to extract all favourite folders and subfolders and the reports in those folders for a specified group.
Can someone help please?
Chris
ChristianKey :uk: (BOB member since 2008-09-19)
This is my query but is not a valid query. What is wrong?
SELECT static, relationships, SI_PARENT_FOLDER_CUID, SI_OWNER, SI_PATH FROM CI_INFOOBJECTS,CI_APPOBJECTS,CI_SYSTEMOBJECTS WHERE
PARENTS(ā€œSI_NAME=ā€˜User-Favouritesā€™ā€, ā€œDESCENDENTS(ā€˜SI_NAME=ā€œUserGroup-Userā€ā€™,'SI_NAME=ā€"’)")
Are you sure you want to know? :twisted:
Nested relationship queries can get very hairy due to the weird rules for delimiter substitution. And more so because they can’t contain newline characters.
If we describe your requirement as:
  1. Get all descendant users of group x
  2. Get all favorites folders for identified users
  3. Get all descendant objects of identified favorites folder
  4. Also include the favorites folders themselves.
we see that it’s a third-order relationship. The following query will do it for the Administrators group:
select si_name,si_kind from ci_infoobjects
where
    descendants
        "si_name='folder hierarchy'",
        "children('si_name=''user-favorites'' ',
                  'children(''si_name=''''usergroup-user'''' '',
                            ''si_name=''''administrators'''' '')')"
    or
    children("si_name='user-favorites'",
        "descendants('si_name=''usergroup-user'' ','si_name=''administrators'' ')")
Note that I’ve formatted this for easy reading. You’ll need to remove all the newlines between the double quotes in order for it to work.
Joepeters, you are a STAR!
That’s exactly what I need! All those quotes and nesting was frying my brain…
Cheers!
Chris :crazy_face:
Glad I could help!
