Quad processor and 2 cpu license
we have 2 cpu license from BO but our Bo server is running on Quad processor with 1 physical cpu currently
is this fine wrt licensing please let me know
or shoudl i buy more licenses
amruta (BOB member since 2007-04-24)
This post could help you.
By the way you should ask your BO sales rep.
thanks thats means i ened 2.5 cpu license and i am haviong 2 cpu license
what do i do now ?
As said in my answer plus in the other post you should double check with BO …
This is not the best resource for legal / licensing questions. We can only speculate as to what your contract says.
Having just gone though this with SAP/BO I can confirm that you would need 2.5 (probably 3 as I never was given the option of buying .5 of a licence) CPU licences for that box.
Options you have are to stump up £75k + support for an additional cpu licence.
Convert your 2 cpu to approx 150 named users (which aren’t cpu dependant)
Virtualise the box using one of SAP/BO’s ‘processor affinity’ approved vendors (we use VMWares ESX server) and limit it to 2 CPU’s worth of processing power.
Cheers.
bourner (BOB member since 2005-01-17)
yes but thsi server has physically only one CPU but Quad processor anyways .
i hope thsi wont be an issue ?
if BO ppl cpome anc check this would it be an issue?
Yes for sure since you are not compliant!
thanks for the update really helpful i shall report this to Bo and ask for the extra license and get it sorted out .
out it manager doesnt know the licensing i need to convince him about this first thanks
If you have less than 150 users (and plan to keep it that way) convert them to named users, unless BO are doing a deal on concurrent users. It gets rid of the daft way that BO charge per cpu.
