I am using QaaWS and when I Add the Host, It generates the query automatically but a warning symbol comes that says “Web Services URL is not Correct”. It does not allow me to go further as OK button is disabled.
Can you please attach the screenshot where the warning actually gets appeared.
Iam confused beacuse when you add a Host, Query won’t be generated rather a URL will be automatically updated.
Sorry for confusion…It’t eh URL that gets generated and and error icon comes just on the right side of the text which tell me that URL generated is not correct.
Do you still need a screed shot…I am at home at the moment…if you need i can attach a screen shot tomorrow from the office
Hi Suruworks,
It should be because of the Application server port number.
When you enter the Host Name in the Name field box, by default a Auto URL will be generated in the down URL Field box and the default port will be 8080(if Tomcat) as shown below.Assuming your using Tomcat Application server
http://HostName:8080/dswsbobje/services/Session
Solution:Change the port number from 8080 to correct Port number
