Qaaws returning 0 when connected to universe
I’ve created queries using Qaaws to pass parameters for user selection on the Xcelsius dashboard. When I test the query and answer the prompts in the QaaWS application I get data, but when I connect the QaaWS query to my Xcelsius model, and then test the .SWF (selecting the same date/group options I selected in QaaWS) it returns 0. Not sure what the problem is or how to troubleshoot it. Any guidance?
ogilrd1 (BOB member since 2007-08-27)
Try using something like Fiddler to trace your web services. Also, you could place some components (like a table) on top of your area where you’re capturing the values coming back from the dashboard.
tracyn712 (BOB member since 2008-06-05)
Is the option Refresh Before Components Are Loaded Checked (In Usage Tab of the QaaWS connection)
Sabita
sabitaparida (BOB member since 2007-05-22)
