QAAWS no result
I’m trying to make a really simple Qaaws but with some universe the query doesn’t return any data.
If I do it with WebIntelligence their is everytime something returned.
I think it comes from a user/app right definition but I didn’t find anything.
Should I configure mu universe for the Qaaws ?
Any idea ?
Thank you
Anonyme (BOB member since 2010-12-24)
If I duplicate the objet, I get the correct data.
So in my dashboard I list both objects friom the same qaaws (original and duplciated) >> only the copied object has data.
But they are exactly the same so I should get two identical columns in my dashboard but one remains empty !!!
It appears to be a software version problem between the server and my client tools (designer/Xcelsius/Qaaws). From a different computer it’s working well by exporting the same universe.
