QaaWS Authentication error
Hello All
I am using BO XI R2 Query as a Web service. After creating a query, I try using the link, but I get the following error.
Any suggestions on what could I do to fix it?
namitrs :us: (BOB member since 2006-11-28)
Also , while troublshooting the trouble I clicked on the one of the link in QaaWS which I think verifies the installation, I got the following message
did you ever get a resolution for this?
amitmanurkar (BOB member since 2009-11-03)
Nope, not yet
hi there!
try this:
  1. stop SIA
  2. stop TOMCAT
  3. start SIA
  4. start TOMCAT
if you still receive the error, remove your proxy server settings in your browsers (if any)
i hope it helps!
r.A.
R.A. :philippines: (BOB member since 2008-10-28)
@ r.A: Does XI R2 has SIA??
Could you please exlain that??
Shiva
shiva.tomar (BOB member since 2007-10-05)
hi there!
SIA is the group of services of Business Objects (that’s in XI 3.x). in XI R2, it doesn’t have a grouping so you should restart all the services listed in the CMS.
regards,
r.A.
SIA is not a group of service rather SIA itself is a server which is used to cover all the other servers and is in sync with the CMS.
For more details BOXI 3.0/3.1 Admin guide at help.sap.com can help.
Shiva
Any luck with this yet?
sdeshpan :us: (BOB member since 2005-06-28)
Did you set the principal properties in the dsws.properties file?
jwhite9 :us: (BOB member since 2006-07-28)
Try doing the same with a enterprise authentication instead of LDAP.
I had the same problem but got it fixed yesterday.
:slight_smile:
V
chanduvk (BOB member since 2010-09-01)
