I am trying to find out if it is possible to access QaaWS using my SAP BW username and password.
I have installed the SAP BOE Integration kit and can authenticate using my SAP BW credentials in Universe Designer and Web Intelligence.
When I build a Universe I use my SAP BW username and password to create the Universe and then afterwards change my authentication method to ‘Single Sign on’ otherwise anyone will be able to access BW using my credentials.
I find that if I am set to Single Sign On (SSO) I am unable to modify queries in QaaWS as of course I am using my Business Objects administrator username and password to log into QaaWS and thus access the query and I suppose these credentials are being used to authenticate against the BW system causing an error.
This is a nuisance as every time I want to amend a query I have to log into Universe Designer and hardcode my username and password before I can proceed with amending the query in QaaWS and then once I have completed the modification I have to change the Universe settings back to SSO mode. Also this can lead to security issues if I forget to change it back to SSO.
Please can anyone offer any advice
Thank you
guinea_girl (BOB member since 2008-12-11)
