Pulling data from SAP ECC- Using a field with date datatype
Hello guys - I am pulling data from SAP ECC using SAP BODS v4.1 SP1. I am having trouble applying filters for a date column in a SAP table. For example, I am using ERDAT as a filter for pulling data from VBFA and the filter applied in the WHERE condition is ERDAT >= ‘2014.01.01’ and ERDAT <= ‘2014.09.30’. This ERDAT column is not an indexed column in SAP so I am using this with VBELN.
With this filter, I am unable to pull any records and the job is timing out in 4 hours and 30 minutes as that’s the limit on the ECC side. I am using ranges for VBELN along with the ERDAT column. Not sure if this is an issue with the date format that I am using for ERDAT and I also tried to_date and to_date(to_char()) options as well but no luck. I am having issue only with a DATE column and only pulling from SAP ECC.
Can anyone please help here? Thanks in advance.
satya1976us (BOB member since 2013-08-30)
