I want to know whether we can achieve the following using Publication. Requirement is after the report refresh if the size of the document exceeds 350kb i want to send a mail alert. Not the report to the inbox
Regards, Kiran
bhkiran (BOB member since 2009-08-05)
The default server component options wont allow to set up such a procedure to block a scheduled delivery.
KhoushikTTT (BOB member since 2005-02-24)
Hi Neo,
Thanks for your reply Is it possible to Alert the user if the Size of th document exceeds certain limit
