Publication a crystal report using webi with range object
I want to publish a crystal report using webi as a dynamic recipient.
In my crystal I have a object with is a month range so input is has a start and end. for example start 2017-M01 and end 2017-M02
in my publication in section personalization if I select edit values of that range object, I select for example 2017-M01 and 2017-M02, when click oke.
this looks in personalization like [201701-2017-M01…201702-2017-M02]
So I thought I use the same format 201701-2017-M01…201702-2017-M02 in webi report but then I am getting below error message when running the publication
The parameter field current values cannot contain discrete values because the ValueRangeKind property is set to
range. (CRS 300003) (FBE60502)
So what should be the format to use in my webi report?
Swimmer :netherlands: (BOB member since 2006-08-23)
