We have two of Source databases which are configured as a Linked Server. We receive this error when our production job is running in BODS 4.0
The database error message is <SQL submitted to ODBC data source <VNHQPSQL01v\bobjpro> resulted in error [Microsoft][SQL Server Native Client 10.0][SQL Server]OLE DB provider “SQLNCLI10” for linked server “CORE” returned message “Protocol error in TDS stream”.>
I checked the connectivity of the Linked Server and it is working fine. Also checked the TCP/IP and Named Pipe protocol which are set in the SQL Server Configuration Manager
I don’t know the SQL Server communication stack as well as I would like to but when I am forced to use SQL Server I always make sure I am connecting using the native client, not ODBC or OLEDB (I never have to configure a DSN). In your Datastore is your Database type ODBC or Microsoft SQL Server? What is the Database version set to in the Datastore?
Is your SQL Server client software up to date? This could be the root of your problem as MS has identified a bug that is related to this error. However, your client software would have to be very old. Since you are on DS 4.0 I doubt this is the case unless you are using a very old O/S install.
And finally, according to a Google search this error can occur when the network is very busy and/or the amount of data to be transferred is very large.
SQL Server 2008 R2
Microsoft SQL Server Enterprise Edition (64-bit) Ver: 10.50.1600.1
We havent installed any Service Pack or Fix Pack on top of the SQL Server 2008 R2 installation.
It might be possible that the error occurs whenever there is a heavy network traffic as one of our Source database has the maximum number of hits.
Would appreciate if you could let me know the fix for the bug in SQL Server 2008 R2 if there are any.
I also checked the log files on Job Server and it only states that
DBS-070404: |Data flow DF_STAGE_TPRODUCTATTRIBUTEVALUE_ALL|Reader Query
SQL submitted to ODBC data source <VNHQPSQL01v\bobjpro> resulted in error <[Microsoft][SQL Server Native Client 10.0][SQL
Although the query is not complicated it fails even while executing simple data flows.
Ran a diagnostic utility called sqldiag but could not find anything related to
the error.
Microsoft SQL Server Management Studio 10.50.1600.1
Microsoft Analysis Services Client Tools 10.50.1600.1
Microsoft Data Access Components (MDAC) 6.1.7601.17514
