Pros and Cons using Publishing Wizard versus Object Browse
Hello All,
At our place,
1.we deploy the Crystal reports to the BO XI R2 enterprise, by Adding “New Object” -> and browse the network and add the report.
2.We are contemplating to use the Publish Wizard to deploy the reports to the Enterprise.Does deploying the reports through Publish Wizard create a CUID?
Would there be any problems with method 1 versus method 2, in future, when we migrate servers?
Please advise.
lalitha (BOB member since 2006-05-05)
Both options should work fine. The big difference between using InfoView to add the reports versus using Publishing Wizard is the speed. Adding files through InfoView is one at a time while Publishing Wizard allows you to add many at once.
JBray :us: (BOB member since 2008-07-15)
Thanks! Will there be a CUID(or any other ID) association if used via the wizard?
