Hi All
I have to create a report with 2 Objects Record Date, Record Name. Below are the list of values.
Record Date Record Name
01-02-2009 Chandra
05-03-2009 Siva
06-04-2009 Ramesh
05-05-2009 Sridhar
6-06-2009 Subbu
15-07-2009 Chaitu
User wants a prompt to be created for No. of Months. If user enters 2 in the Prompt then report should filter date for the last 2 months data based on current date.
With the above example, current date: 11-08-2009 minus 2 months is 11-06-2006. Hence report should show record dates setup during this period.
15-07-2009 Chaitu
User can change No. of Months value dinamically each time the report is run and based on that the report should show the records.
Thanks to help us.
Chandra
vcoreddy11 (BOB member since 2006-09-02)
