Prompt select values
I want my prompt window to show values to select in the report.
gu.rashmi (BOB member since 2011-06-09)
If you are using an object in your query prompt, it is likely that the object does not have LOVs enabled.
If the object has LOVs but you are using a pre-defined condition, then the parameter for the LOV has not been set.
Mohan :us: (BOB member since 2002-08-15)
