HI
I need dynamic filters in my crystal reports. For This I am creating the Prompt logic in the objects.but I am getting the error when I parse. I don’t why I am getting this error. Could you please suggest where I am making mistake :
The default value {‘WNET’} has to be placed earlier, not as the last parameter. The last parameter is for the Order of display of the prompt. If you are on XIR2, even after this change, the object will not parse, because the extended syntax of @prompt (not_persistent and order of prompts) is not recognised in the Universe. When you use the object in the report, it will work despite it not parsing.
