Prompt in Lumira
Is it possible to do prompt in Lumira version 1.31.4. If it is, what are the steps to create a prompt?
Singaram
kumaran22 (BOB member since 2010-07-14)
Not possible.
I found a solution to this problem.
  1. Go to File and select Extensions.
  2. Click on the SAP Universe Query Panel from the dialog box.
  3. This will install the Query Panel.
  4. You will to restart Lumira.
  5. Next time you add a dataset you will see you will see SAP Universe Query Panel
  6. Select this option and the SAP Universe Query Panel will be displayed. Here you can define your objects and prompts.
Yes, but this is limited to Universe connectivity, which you didn`t state as a requirement.
Now that I found a solution that allows prompts, I am not able to see the prompts when I do a refresh of the query. They are mandatory prompts.
