system
1
Helloooo!
Im trying to create a @prompt so every time a user makes a report using this universe, inherits the prompt.
I mean, though you dont create this prompt in the report but in the universe, you will be forced to fill the prompt to execute the report.
How can I do this?
Thanks!
Victor_BCN
(BOB member since 2009-09-15)
system
2
Ok, I found it out
I just to create it as a Filter, and check “Make it compulasory in the query” (sorry for the translation to english
Now everytime I do a report using this universe Im forced to fill this prompt
Victor_BCN
system
3
It is called “mandatory” filter, which can be set for the universe or at the class level within a universe, great new feature in XI R3.x
Andreas
(BOB member since 2002-06-20)
system
4
Andreas, can you tell me how to create such filter.
Did you mean by defining condition in WHERE clause of the object definition?
Rakesh_K
(BOB member since 2007-12-11)
system
5
I wrote a blog post about it a while back that explains it.
Dave Rathbun
(BOB member since 2002-06-06)
