Prompt Display
Simple Excel document using a universe query - two filters both use prompts:
Activity Date - date between prompt range values
Employee Name - allows multiple values
The data is correct, but is there a way to display the prompt values so that the user will know what dataset is being displayed?
dukeslater (BOB member since 2007-02-15)
Spoke to SAP support - can’t be done when basing LO document on universe query, but I can create a Webi report based on the same query and pass the prompt values to LO by embedding the prompt formulas in report fields.
