@prompt date function with lookback - Freehand SQL
I’m using freehand SQL in my BO report and am needing to come up with a way to have the ‘Start time’ that the end user selects look back an additional 7 days. For example, if September 8, 2023 is selected have the date actually start at September 1, 2023.
Is this possible?
Much appreciated for looking.
Paul
SELECT DISTINCT
 tc2.tracking_id,
 tc2.tracking_checkin_id,
 tc2.checkin_dt_tm,
 DENSE_RANK() OVER (PARTITION BY tc2.tracking_id, tc2.tracking_group_cd ORDER BY tc2.tracking_checkin_id ASC) keep_date
FROM
 tracking_checkin tc2
WHERE
 tc2.tracking_group_cd = 2560254871 and
 cast(from_tz(cast(tc2.checkin_dt_tm AS TIMESTAMP),'GMT') at time zone 'US/Eastern' as date) BETWEEN @prompt('Start time:','D',,mono,Free,Persistent,,User:0) AND @prompt('End time:','D',,mono,Free,Persistent,,User:1)
Sure. I am going to assume your database is SQL Server. If not, the syntax may need to be adjusted.
All you need to do is wrap your Start time prompt with a DATEADD function.
SELECT DISTINCT
 tc2.tracking_id,
 tc2.checkin_dt_tm,
FROM
WHERE
 BETWEEN DATEADD(DAY, -7, @prompt('Start time:','D',,mono,Free,Persistent,,User:0)) AND @prompt('End time:','D',,mono,Free,Persistent,,User:1)
Thanks for the suggestion. I’m using Oracle SQL so DATEADD will not work.
But you can get this approach to work if you experiment. Try wrapping your entire first prompt in a TO_DATE function and then subtract 7 like this…
TO_DATE(@prompt('Start time:','D',,mono,Free,Persistent,,User:0)) - 7
nscheaffer, the TO_DATE function worked great. Thanks so much for the solution. I really appreciate it.
