Prompt as input field in Xcelsius dashboard
I have set my prompt in xcelsius and the values are displayed based on my prompt value. My Prompt is for V3/fiscal year 2017.
I have generated 2 dashboards. One with pie chart and other one with bar chart which is a insertion of pie chart.
My requirement is
  1. Prompt value to be the input field for user : That is the user has to be given chose to choose the year and based on which my preview in xcelsius to be refreshed
  2. My second bar chart even though it is an inserttion of pie chart, i wanted first this second chart to display value based on prompt values and then only the insertiion should behave (ie. when i drill down any part of pie charts its corresponding value should get displayed)
How to enable this.
Prema
Prema (BOB member since 2017-09-11)
Welcome to B:bob:B!
I will move this to the Xcelsius forum for you. Good Luck 8)
Have a look at this, which might get you started: Using a Stacked Bar Chart to show results
Debbie
