When I create a Full backup , multiple files are created, even when using the time stamp.
Are all needed, or should I use the last created?
I using 4,2 sp 9
LCMbiar have a size limit, it will automatically split your lcmbiar in multiple files if size is too big.
So you need all the files for it to be correct and usefull.
In case you need to retrieve your files from the lcmbiar, you’ll have to load the first one and BO will automaticaly load the other files.
Be carefull, if you have multiple files, the process will be long and may be painfull
That’s what I was afraid of
