Hi Experts,
I’m new in Data Services and Rapid Marts and need your help.
There is a new BODS installation with successfully integration of the Rapid Marts Content.
Systems:
- Data Service Designer, JobServer and JobEngine 14.1.1.210, Repository 14.1.1.000
- SAP HANA via SAP HANA Studio Version 1.0.48
- SAP R/3 - EHP6 FOR SAP ERP 6.0, Releas 731, SP 3
All three on independent server machines but on the same lan network and the Communication between the Systems (HANA, R/3 and BODS) works.
Even the test jobs worked without any Problems.
But when I tried to execute the Production_Planning_Load_SAP, the Job failed with several Error-Messages.
This is the Error_log:
9568 10112 RUN-051038 2/15/2013 4:58:07 PM |Data flow DF_TimeDim_SAP|Transform Table_Comparison
9568 10112 RUN-051038 2/15/2013 4:58:07 PM Warning: Data truncation occurred while loading a INT column.
2388 9312 XRN-130109 2/15/2013 5:02:04 PM |Sub data flow DF_WorkCenterHierVr_SAP_1_3|Transform Hierarchy_Flattening
2388 9312 XRN-130109 2/15/2013 5:02:04 PM The hierarchy values CP-RN-02 CP-F0002CP51D->CP-RN-02 CP-F0003CP51D->CP-RN-02
2388 9312 XRN-130109 2/15/2013 5:02:04 PM CP-F0004CP51D->CP-RN-02 CP-F0005CP51D->CP-RN-02 CP-F0003CP51D> input to transform <Hierarchy_Flattening> form a circular
2388 9312 XRN-130109 2/15/2013 5:02:04 PM dependency. Check the input data for correctness.
5644 7004 FIL-080134 2/15/2013 5:02:51 PM |Dataflow DF_WorkCenterHierVr_SAP|Pipe Listener for DF_WorkCenterHierVr_SAP_1_3
5644 7004 FIL-080134 2/15/2013 5:02:51 PM Named pipe error occurred: <The pipe has been ended.
5644 7004 FIL-080134 2/15/2013 5:02:51 PM >
5644 9776 DFC-250038 2/15/2013 5:02:51 PM |Dataflow DF_WorkCenterHierVr_SAP
5644 9776 DFC-250038 2/15/2013 5:02:51 PM Sub data flow <DF_WorkCenterHierVr_SAP_1_3> terminated due to error <130109>.
5644 9236 FIL-080134 2/15/2013 5:02:51 PM |Dataflow DF_WorkCenterHierVr_SAP|Pipe Listener for DF_WorkCenterHierVr_SAP_1_1
5644 9236 FIL-080134 2/15/2013 5:02:51 PM Named pipe error occurred: <The pipe has been ended.
5644 9236 FIL-080134 2/15/2013 5:02:51 PM >
5644 9512 FIL-080134 2/15/2013 5:02:51 PM |Dataflow DF_WorkCenterHierVr_SAP|Pipe Listener for DF_WorkCenterHierVr_SAP_1_2
5644 9512 FIL-080134 2/15/2013 5:02:51 PM Named pipe error occurred: <The pipe has been ended.
5644 9512 FIL-080134 2/15/2013 5:02:51 PM >
9708 9304 DFC-250038 2/15/2013 5:02:52 PM |Dataflow DF_WorkCenterHierVr_SAP
9708 9304 DFC-250038 2/15/2013 5:02:52 PM Sub data flow <DF_WorkCenterHierVr_SAP_1_3> terminated due to error <130109>.
I will be grateful for any help you can provide.
Many thanks
Ruth
Ruth (BOB member since 2013-02-21)
