Problems with performing a Type 2 SCD in DI
I know its a fairly easy question, but is there anyway of implementing a Type 2 SCD given the following (made up) dimension table structure.
Surrogate_Key
Natural_Key
Description
Price
I want to insert a record in to the dimension table for each new record that doesn’t already exist in the dimension table, and insert a record when the Description/Price changes for records in the dimension table with the same Natural_Key.
I.E.
Dimension Table (Surrogate_Key, Natural_Key,Desc,Price)
1,1,‘Blue Jeans’,£25
2,2,‘Red Shirt’,£15 <- current version
3,3,‘Greenish Socks’,£2
4,1,‘Blue Jeans’,£27 <- current version
5,3,‘Greenish Socks’,£3 <- current version
Source - To be checked/loaded
(Natural_Key, Desc, Price) - surrogate key is only in the dimension
1,‘Blue Jeans’,£27
2,‘Red Shirt’,£15
3,‘Green Socks’,£2 <- changed
4,‘Black Hat’,£7 <- new
What I want to go in to my dimension table is:
6,3,‘Green Socks’,£2
7,4,‘Black Hat’,£7
So I end up with:
2,2,‘Red Shirt’,£15 <- Current Version
4,1,‘Blue Jeans’,£27 <- Current Verison
6,3,‘Green Socks’,£2 <- Current Version
7,4,‘Black Hat’,£7 <- Current Version
What usually happens is that the ‘Blue Jean’ source record gets inserted again in to the dimension table (because £27 - Source is not the same as £25 ONE of the dimension record values)
I don’t have any current_flag type columns, or effective_date columns.
When comparing the Desc/Price I always want to compare the Natural_Key in the source with the record in the dimension table with the same Natural_Key and the greatest (max) Surrogate_Key - Thats how I find the current version in the dimension.
I can’t seem to find a Source–>TC–>HP/MO–>KG–>Target combination that works…I end up with multiple records going in to my dimension table, as the TC compares all previous occurances of my Natural_Key and not just the ones with the greatest Surrogate_Key.
I hope this makes sense !!!
Graham
GSmith :uk: (BOB member since 2006-10-25)
Remove the Map_Operation - normally not required.
In the TC, do you have the generated_key field filled with the surrogate key? That’s causing the TC to look for the highest key instead of anyone.
Thanks wdaehn for you reply.
As suggested I removed the MO, so was left with the following DF
Source -> Query -> TC -> HP -> KG -> Target
I ensured that the Natural_Key was in the Input Primary Key Columns list and the Generated Key field in the TC was populated with the Surrogate_Key ( as I only ever want to check the LATEST Surrogate_Key per Natural_Key) and that my compare columns were in the HP transform and I all worked how I wanted it to.
I never realised that putting the Surrogate_Key in the Generated Key Field would only match the lastst records in the compare table. I do now though !!
Thanks again.
GS
