Im getting a problem, i have 2 clients Windows XP with Designer.
One client is connecting normaly, I can connect in the server, import universes and work on them.
The other one, its connecting as well, but when i try to import, i get the folow error:
Failed to initialize import/export dialog.
Previous Error: Failed to retrieve root universes folder. You may not have permission to view this folder.
Some consideration:
Both computers are using the same user, Adminitrator.
The first client conect using only the ip:port like 192.1.1.1:6400. The second one just get connected if i put @192.1.1.1:6400 (J2EE Portal).
Something is not right. The J2EE Portal option should only appear in DeskI, if you’ve connected in three-tier mode previously. It shouldn’t show up as an option in Designer.
I’m assuming that you’re IP isn’t really 192.1.1.1. Can you connect the second machine using the actual CMS name?
Please give the details what have you added in hosts file. I am facing the same issue.
Starnge thing is my other friends are being able to login into Designer, but I cant. I checked the network settings, they are same except the IP Address.
CMS BOXI R3.1 running on HP Unix 64 Bit, client tools running on Windows XP SP3
