I have a user who is developing an dashboard in Xcelcius 2008. The source Excel file is about 168K in size and when either he or I tries to preview the dashboard Xcelcius 2008 displays the “Generating swf” dialog for a few minutes, then it displays an “Initializing…” progress bar which moves about a 1/3rd of the way across. At that point Xcelcius seems to “freeze”, but if you look at the task manager shows the xcelcius.exe process consuming huge amounts of memory (800+MB) and CPU (50%+) and then it goes idle.
The same is true if I export the dashboard as a .swf file and then try and view the file in Internet Explorer 6, except that IE consumes hugh amounts of memory and CPU then goes idle without displaying the dashboard. Eventually, I end up killing the process as it seems to be frozen.
I searched the BO support site as well as googled this issue, but found very little content regarding Xcelcius 2008. Any ideas, or thoughts about other things to try would be appreciated.
alpha1145 (BOB member since 2006-01-04)
