I am plotting a graph using the Line chat ,the X-axis is showing uneven values
I have data like this
1
4
5
7
10
The values plotted on x-axis are
1 4 5 7 10
i want something with the constant range like
0 2 4 6 8 10
This usually happen in XY Scatter chats in Excel
I want this feature in Webi XI r2
If not is there any add on which we can use in Webi to design the XY Scatter chat .
Youe help is much appreciated
Thank you
Malik
Regarding-1 : As i have no access to turn it and see the properties. I meant it in Line chart.
Regarding-2 : Use Analysis Context or Drill bar and place the object(s) on which basis you want to see the data. It will show/give LOV’s , So that users can select and it will change chart values based on the selection.
I need XY Scatter Chart which is in Excel.Users have used excel graph,they are expecting similar behaviour in this webi report also.These are Static reports.Users will select the prompt and they are expecting the reports to be filled and graph to be plotted.
the suggestion you said me i dont know how to implement.I am new to Webi.can you please check ,it can meet my requirement of XY Scatter Chart in Excel.if Yes
Can you please explain me in details ,how i can achieve this.
Thank you very much for your reply.
Malik
