BusinessObjects Board
Problem with refresh in Dashboard 4.1 SP2
Hello,
I have created a dashboard and used BIWS to get the data from scheduled webi reports I created.
Everything works fine except the refresh button or if I set a refresh every xx min in the queries.
When I refresh the report using the refresh button (or if I parameter the connection in Dashboard to refresh every 5 min), the first time it refreshes, it empties the dashboard, I have to refresh again to get the refreshed data and then if I click again it empties the report again etc.
So basically if I set an automatic refresh every 5 min, for 5 min there is no data, then there data for 5 min, then no data for 5 min etc.
The initial refresh before component are loaded works fine though.
I can’t believe that’s the normal behavior of the tool.
Has anybody already experienced this problem and could tell me how to fix it?
I don’t really see myself telling the user they have to click the refresh button twice to get refreshed data…
Adrien
adrien.lozano (BOB member since 2011-11-09)
