Problem with Date format
I have date field it is in MM/DD/YYYY HH:MS;SS AM/PM format , I want to modify this field in format of DD-MON-YYYY .
I tried with to_char(Date,‘DD-MON-YYYY’) , it is giving error . If it works also when I run the report I cant put filter on dates because this is character type .
Can some one please let me know how to get date field in format of DD-MON-YYYY and data type is Date .
Thanks in advance .
patriot3029 :india: (BOB member since 2006-12-08)
Just format the object at universe level - it’s a menu option in Designer.
Or see this topic:
Debbie
Thanks for reply ,
I Can see format DD-MON-YYYY when I take object in Result Objects panel .
Proble is when I pull same object to Filter pane I am seeing different format (MM/DD/YYYY HH:MS:SS AM?PM) There I want to see same format DD-MON-YYYY .
Please some one let me know How to do that .
Use below code as a object definition with datatype date.
to_date(to_char(Date,'DD-MON-YYYY'),'DD-MON-YYYY')
Create a filter in Universe designer
TRUNC(tabele_name.date_coumn,'DD') = to_date(@Variable('Enter date'),'DD-MON-YYYY')
Piotr.Caban :poland: (BOB member since 2009-01-19)
Thanks for reply ,
How to get List of values in Queery Filters pane in format of “DD-MON-YYYY”
Create dimension object with associated LOV.
Type:Character
Select: to_char(table_name.data_col,'DD-MON-YYYY')
Create filter:
TRUNC(tabele_name.date_coumn,'DD') = to_date(@Prompt('Enter date',A,'Class name\My Date',MONO,FREE),'DD-MON-YYYY')
