One of our clients recently upgraded to version 5.0.1. They opened a version 4.1 report in version 5 and the crosstab does not seem to work. When the version 4 report is opened in version 5, only the first column of the crosstab is visible – all others are gone!! When the same report is re-created in version 5 from scratch, it works just fine. Has anyone run into something like this? Thanks for your help.
Chander Aggarwal http://www.compuexcel.com the home of BusinessObjects Essentials. The world’s first Web/Computer based training for BusinessObjects and WebIntelligence.
I believe that is a bug in 5.0, 5.01 - I think it is addressed in 5.02
Brent
We upgraded from 4.1.3 to 5.0, then 5.0.1 and experience the same problem. SP1 has not made a difference. It happens most often with reports containing detail dimension objects and user defined variables. Anyone know if its addressed in SP2?
