problem with connecting BO with oracle
Hi to all BOB forum members,this is my first post.
Problem:
I have installed BO 6 V and Oracle 8i in my laptop.upto here i am okay
i am facing problem here,after installing oracle i am able to work on BO using oracle db but once i sutdown my system and restart then oracle is not responding.Os is XP prof. thank you in advance
pracalus…
pracalus (BOB member since 2005-04-21)
Welcome to B :mrgreen: B :!:
Do you mean that you cannot restart your Oracle DB in your laptop ?
What do you mean exactly by “not responding” ?
Grodan :fr: (BOB member since 2004-12-29)
you have installed oracle client or server in your laptop
Rajasekar :india: (BOB member since 2004-07-16)
first thanks for your immediate reply.i am not able make connection to database from BO and i also tried
opening SQL Plus ,after entering scott and tiger its saying
TNS is not available are not exist something like.and also when i am tring
to start oracle from controlpanle >services,its thr’ing error.
Hi rsekar,
i had installed Oracle Client.
Since you have installed Oracle client so it is not responding, I think you should have to install Oracle server in your laptop.Create a new db then you can access.
The DB you try to access is in your laptop or in another server ?
grodan,
DB is in my laptop.everything is in my laptop only.its not connected to any other computers.
As said resekar, Oracle client is only used to connect to an existing DB. You have to install Oracle server in your laptop and create a DB.
First of all you have install a oracle server in your laptop and then create a database in the oracle.Then you install BO and configure the bomain key using oracle db. :slight_smile:
hi
sorry for giving you guys lot of trouble.i am trying to install
Oracle 8 i again ,there are some options
Oracle 8i 8.1.6.0.0
Oracle 8i Client 8.1.6.0.0
Oracle 8i Management Infrastructure 8.1.6.0.0
Previously i had installed Oracle 8i not client, as you guys suggested me
to install oracle server but i didnt see this option .please help me
As far as I know, Oracle 8i is not supported under Windows XP. 9i works well though. Just a thought for a starting point.
scuzball1 :us: (BOB member since 2005-04-25)
