Problem: measure for Month to Date returns 0
Hello,
I need to calculate the measure value from the first of this month to
todays date… I read thro the forum topics for month to date and came up with this sql statement… but it doesnt seem to work…it gives zeros…
avg(case when (TRUCK_UTLIZATION_FACT.SHP_DT>= trunc(SYSDATE,'month') and TRUCK_UTLIZATION_FACT.SHP_DT< =SYSDATE) then TRUCK_UTLIZATION_FACT.INBOUND_TRUCK_UTILIZATION
 end )
pls help me…also i need to generate an object for the same month last year …
thanks in advance
newbee
[edited, changed topic title. Please, choose a more meaningful title for your topic other than “urgent help” next time. Thank you, Andreas]
newbee (BOB member since 2004-07-23)
I’ve tried:
Select avg(case when (SC.CALLDATETIME >= trunc(SYSDATE,'month') and SC.CALLDATETIME <=SYSDATE)
then SC.CALLAMOUNT
end ) From Salescall SC
in Toad and it works like a dream… So your SQL seems to be in order (just removed the space between ‘<’ and ‘=’).
At least, I don’t have any zeroes. If the amount is the correct average: I didn’t test.
jobjoris :netherlands: (BOB member since 2004-06-30)
Hello jobjoris,
Thank you for the response but it doesnt seem to work
it still calculates zeros…
newbee :reallymad:
And what does
Select trunc(SYSDATE,'month'), TRUNC(SYSDATE)  from dual
return?
Maybe you should do a trunc around your last date (so it removes the time if it’s a date-time field).
Please try to use descriptive titles for your postings. It makes the searching more efficient. TIA
Chris Pohl :us: (BOB member since 2002-06-18)
Hello jobjoris,
thank you…
the output (sysdate,“month”) is 8/1/2004 and for trunc(sysdate) is 8/11/2004
the same statement worked for the YTD object (cal from 1st jan to tilll date)
i tried trunc for the last date …it didnt help either…
newbee
hello chris pohl,
sorry…i realised that after i posted my msg…
thanks for correcting that…
newbee
thanks for ur responses…
I got it fixed with this code…
avg(case when
to_char(TRUCK_UTLIZATION_FACT.SHP_DT,'MM-YYYY') >= to_char(SYSDATE,'MM-YYYY')
and TRUCK_UTLIZATION_FACT.SHP_DT <=SYSDATE
then
else 0
end)
…now Im left with generating the same object for previous year(from sysdate)…
can anyone help me…
forgot to mention…i tried add_months but it wouldnt work
it gives me missing right paranthesis error…I m sorry it is a pretty crude way to code …
avg(case when
to_char((add_months(TRUCK_UTLIZATION_FACT.SHP_DT,-12),'YYYY')] >= to_char(add_months(SYSDATE,-12),'YYYY')
and (add_months(TRUCK_UTLIZATION_FACT.SHP_DT,-12) <=add_months(SYSDATE,-12) ]
then  TRUCK_UTLIZATION_FACT.OUBOUND_TRUCK_UTILIZATION end )
thanks in advance for ur help
newbee
correction to the previous code
avg(case when
to_char((add_months(TRUCK_UTLIZATION_FACT.SHP_DT,-12),'MM-YYYY')] >= to_char(add_months(SYSDATE,-12),'MM-YYYY')
it is still not parsing
Try:
AVG
CASE
WHEN
   to_char ( add_months (TRUCK_UTLIZATION_FACT.SHP_DT, -12), 'YYYY')
   >= to_char ( add_months (SYSDATE, -12), 'YYYY')
   AND
   <= add_months (SYSDATE, -12)
THEN
END
Note:
Do not use ]
Remove the “]” and us “)”
Edit: Oops, Andreas was one step ahead of me…
thanks Andreas …
the code parses well but I get SQL sentence error (when i try to use the object on the report )-- not a single-group group function
newbee
