Problem finding Number of Days between 2 dates
Hi All
I tried using the below resolution provided in the knowledge base.
But I am having problems.
I am getting -ve values once I use the below process.
Here the formula is taking the difference as Minutes - minutes, hours - hours, seconds - seconds.
It is not considering the the hours while subtracting the minutes and minutes while subtracting the seconds.
  1. Create a variable Days to get the number of days between the two dates.
    Number of
    day:
    =DaysBetween( ,)
  2. To get the number of hours:
=ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,1 ,2))-
  1. To get the number of Minutes:
=ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,4 ,2))-
  1. To get the number of Seconds:
=ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,7
,2))- ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,7 ,2))
  1. Concatenate these variables like:
Hope I am clear in my explanation.
THanks in advance.
B…
bobjkb :india: (BOB member since 2004-03-19)
You’re right, that solution does nothing to calculate the remaining hours, minutes, seconds, etc.
You will need to determine the number of days, then take the whole number and subtract that from the total. Use the remainder in the calculation for hours. Then take the whole number from that and subtract from the total. Take the remainder from that and use in the calculation for minutes. Keep going until you have calculated the number of seconds.
Judy
JMulders :us: (BOB member since 2002-06-20)
Thanks a lot for the reply.
Could you please let us know how exactly this can be done ?
B…
Try,
KhoushikTTT :us: (BOB member since 2005-02-24)
Hey Neo
That is where I am getting the -ve values.
[Moderator Edit: Please avoid obsure abbreviations. Please spell out negative rather than -ve, for example.]
B…
This Solution might help…to calculate the number of hours between two dates…May need to change a bit to get seconds…
Ravi
ravi_prk (BOB member since 2004-09-03)
Hi B…
This is a bit dumb but it works.
Diff gives the difference between the dates.
Date 1 (dec 1 2005)is allways an earlier date compared to Date2(dec 10 2005)
=DaysBetween( ,)
=(ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,1 ,2))*3600)+(ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,4 ,2))*60)+(ToNumber(SubStr(FormatDate( ,“HH:mm:ss”) ,7
,2)))
,2)))
= If (>) Then (Abs()+“d:”+(Floor((-)/3600))+“h:”+Floor(Mod((-) ,3600)/60)+“m:”+Mod((Mod((-) ,3600)) ,60)+“s”) Else (Abs(+1)+“d:”+(Floor(Abs((+86400)-)/3600))+“h:”+Floor(Mod(((+86400)-) ,3600)/60)+“m:”+Mod((Mod(((+86400)-) ,3600)) ,60)+“s”)
  • YSS -
yss (BOB member since 2005-02-26)
