system
September 1, 2011, 1:48pm
1
Hello!
Is it possible to select “Fit to one page” when you are going to print at BOXI 3.1 Infoview?
My only solution so far is to export to Excel and then select “Fit to one page” but that is not a good solution (takes to long time).
Br Elgasen!
Elgasen (BOB member since 2007-09-21)
system
September 2, 2011, 1:38pm
2
In Webi you can set the report to fit to page as described within Webi help:
You can change the number of horizontal and vertical records per page in Quick Display mode in Web Intelligence.
In the Java Report Panel, set the Page Content > Vertical Records per page and Page Content > Horizontal Records per page properties.
In Web Intelligence Interactive, right-click the report background, select Format Report to display the “Format Report” dialog box, and set the Number of vertical records per page and Number of horizontal records per page in the General tab.
If you are in EDIT mode, this can be set up by adjusting the page properties (Go to left hand side properties tab and on the report panel click anywhere on the background) after toggling to the Quick display mode
Uvee (BOB member since 2005-10-26)
system
September 2, 2011, 2:09pm
3
In 3.1, you dont have that feature when printing from InfoView/WEBI. Its only available within Deski-reports.
That is one of the new features for WEBI in BI4.0. So be extra patient, and wait for the new version…
“Vi hörs”
/Björn
Bjorn (BOB member since 2006-02-10)
