BusinessObjects Board
Preview as Mobile for Dashboards
I have developed a Dashboards in 4.1, Sp4, my question is I would like to preview it in Mobile mode.
However, when I go to Preview, click on Mobile (Fit to screen) , it brings up the Dashboard but none of the web services work so there is no Data to display.
When I click for Desktop display, it prompts for login and pw, however when preview in Mobile, the login dialogue box does not appear.
I hard coded my username and password for the web services in the left pane of Data Manager but nothing happening.
I haven’t gotten down to connecting to iPad yet, I am simply trying to view a normal Dashboard in Mobile Preview, Can someone give me step by step instructions. Appreciate!
:crazy_face:
FOUND THE ANSWER, I AM ON BI4, DASHBOARD MOBILE WILL ONLY WORK WITH 4.1, SO NEED TO UPGRADE.
QAAWS DOESNOT WORK ON 4.0
americanmc :hong_kong: (BOB member since 2009-12-31)
There are some components it doesnt work in Mobile mode.
Best practices says “if you will view your dashboard in mobile mode, first of all you must put just mobile components”
:wave:
edumen (BOB member since 2013-04-23)
