Is there a way to prevent a user from removing a DrillFilter? They to be able to change the DF’s value, just not select the (remove) value.
craibuc (BOB member since 2009-10-19)
Hi…
Were you able to get a solution for this…?
learner16 (BOB member since 2009-05-28)
